I would Pick up a call using BLF on 3CXSoftPhone
Discussion in 'Windows' started by Cor i Luz, Feb 23, 2016.
  1. Cor i Luz
    Oct 28, 2015
    6
    Hello
    While an extension is ringing (call incoming) I can pick this call from an aother exrension by pressing the BLF on a snom821
    But the same is not possible using the SoftPhone (in Phone mode )
    Do I miss something ?
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,338
    77
    Currently you cannot pick up a Queue call using a BLF key on the 3CXPhone app that is ringing on another extension, all other calls though should be OK. I think this currently causes some issues with the call reports.
    If you cannot pickup any call using a BLF on the 3CXPhone app, make sure in the Management Console in the Extension Settings of the 3CXPhone extension, in the "Rights" tab that you have the "Perform Operations" checked.
