ID 4101 Extension DialCode is unregistered
Discussion in '3CX Phone System - General' started by precisetaxes, Aug 27, 2012.
  1. precisetaxes
    Aug 27, 2012
    I get this error messaged emialed to me
    ID 4101 Extension DialCode is unregistered, removed contact:sip:DialCode@127.0.0.1:5488
    And the system stops working entirely. Phone calls can't be received or made. I can't even access the 3CX PC via the browser or via remote desktop, even when on the same LAN.
    I temporarily fixed it with a power button reboot, but an hour later I got the error again the system stopped working and stopped being accessible again.
    Any ideas?
    Scott
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,552
    298
    What are the server specs? # of NIC Cards? IP scheme?
  3. precisetaxes
    Aug 27, 2012
    1 Nic card. Its on the 10.2.10.0 network. 64 bit windows 7 machine.
  4. craigreilly
    Feb 1, 2012
    3,552
    298
    Can you post more of the logfiles around this error?
    Also, ensure NIC Card has only 1 IP Address.
  5. precisetaxes
    Aug 27, 2012
    NIC card has only 1 address. System seems to just suddenly want to reboot and then can't find the proper reboot file and just freezes in a dos-like screen. Log files don't show anything unusual.
  6. craigreilly
    Feb 1, 2012
    3,552
    298
    This sounds like more of a Windows issue.
    Maybe a bad network card and/or driver ?
    Is it using the Windows driver or the NIC Mfg driver ?
  7. precisetaxes
    Aug 27, 2012
    I think you're right. I 'm going to rebuild a new server. Where do I go to download the version of 3CX that I have? Small Business Edition 8SC. Product Code 3CXPSSB. I have a license key. the only downloads I can find are for the free version.
  8. craigreilly
    Feb 1, 2012
    3,552
    298
    All software is the same. The license key unlocks features.
