ID4100 - Registration for Trunk has changed
Discussion in '3CX Phone System - General' started by haywardi, May 10, 2013.
  1. haywardi
    Feb 27, 2011
    84
    I received an email with the above subject and message text as below.
    My natural assumption was that I had been de-registered and then re-registered from my SIP provider.
    To see how long I had been disconnected for I had a look at the server log (again below) in verbose mode. At the time of the re-registration, there is NO ENTRY in the log...., in fact there is no entry in the log say I had been de-registered.
    Now to my question, is this a glitch in the 3cx warning system? Is it a fault in the server log?
    Thoughts?
    Email Message
    (0) Server1 10/05/2013 14:17:40
    Event source: 3CXPhoneSystem
    Trunk L:10000(xxxxxxxx) has changed status to registered.
    Server Log
    10-May-2013 14:19:18.247 Currently active calls [none]
    10-May-2013 14:18:48.245 Currently active calls [none]
    10-May-2013 14:18:16.243 Currently active calls [none]
    10-May-2013 14:17:44.242 Currently active calls [none]
    10-May-2013 14:17:14.240 Currently active calls [none]
    10-May-2013 14:16:42.238 Currently active calls [none]
    10-May-2013 14:16:10.236 Currently active calls [none]
    10-May-2013 14:15:38.234 Currently active calls [none]
    10-May-2013 14:15:06.233 Currently active calls [none]
    10-May-2013 14:14:34.231 Currently active calls [none]
    10-May-2013 14:14:04.229 Currently active calls [none]
    10-May-2013 14:13:32.227 Currently active calls [none]
    10-May-2013 14:13:00.225 Currently active calls [none]
    10-May-2013 14:12:30.224 Currently active calls [none]
    10-May-2013 14:11:58.222 Currently active calls [none]
    10-May-2013 14:11:26.220 Currently active calls [none]
