Identify the provider the call is coming from.
Discussion in '3CX Phone System - General' started by lrodis, Jan 23, 2009.
  1. lrodis
    Oct 28, 2008
    9
    I'm using two different SIP trunk providers and a mixture of 3CX VOIP Clients and Grandstream 1200 phones.
    What I want to do is be able to identify on the display which of my Phone Numbers/SIP providers is receiving the call.
    Thanks in advance.
    BTW the Grandstream1200 configures just like the Grandstream2000
    Larry
  2. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    This is currently not possible without losing other functionality, as you would need to play around with the inbound parameters.
  3. lrodis
    Oct 28, 2008
    9
    OK. Is their some other way to identify what incoming line the call is coming in from?
    Larry
  4. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Hi Larry,
    Could you please specify the business case and/or environment which requires such kind of information?
    P.S. Please exclude description of hypothetical scenarios. They are "hypothetically" supported ;)
  5. worksighted
    worksighted New Member
    Aug 19, 2008
    204
    Just create a DID to bring the call in on for each provider and name it something like "provider1" and "provider2" and enable append DID/queue to caller ID. Then you will know.
    Best,
    Mike
  6. lrodis
    Oct 28, 2008
    9
    Business case.
    You running two businesses and have some people who answer both phones.
    I'm going to play with Mikes answer and see if that works.
    Larry
  7. lrodis
    Oct 28, 2008
    9
    Mike,
    Is there a way for this to work without creating call queues?
    Larry
  8. worksighted
    Aug 19, 2008
    204
    How is you inbound call routing currently setup? Do you have only 1 main number? Where does that ring to?
    Mike
