Idle Timeout in SP3 MyPhone
Discussion in '3CX Phone System - General' started by KerryG, Sep 26, 2011.
  1. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    We had a lot of requests from resellers asking for an idle timeout in myphone to automatically change the presence status. This feature was added with SP3. To learn how to configure it we did a blog post about it.
    http://www.888voip.com/configuring-the-new-idle-time-out-in-3cx-myphone-v10-sp3/
  2. andrewbucklin
    Jun 30, 2011
    12
    Is this not available on the OSX version of MyPhone?
  3. nbailey
    nbailey Member
    Jan 31, 2011
    359
    desktop components need to be installed for this to work. So therefore since desktop components cannot be installed on a MAC this feature is not available.
    Thanks,
    Nate
