IE11
Discussion in '3CX Phone System - General' started by HeMan, Feb 27, 2014.
  1. HeMan
    May 17, 2010
    7
    Any sign of IE11 compatibility?
    I know MS used to have a bad rep on standards but haven't they been getting better of late, so why does 3CX refuse to work at all?!
    I understand you can mess around with compatibility mode, but if it works with that turned on (which I guess just changes the agent string) why can't they just fix it?
  2. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    Maybe you should use the ideas app to suggest it
    http://www.3cx.com/blog/news/new-3cx-ideas-app/
