If you reject a phone - where is the rejection list kept?
Discussion in '3CX Phone System - General' started by martinpluss, Nov 29, 2011.
  1. martinpluss
    Jun 28, 2011
    30
    Just wondering if anyone knows the answer to this. Say you plug in a bunch of upnp handsets they all appear under 'Phones' in bold as you'd expect ready for provisioning then you click one and hit the reject button.
    Where does 3CX store this list of rejected phones? Does it every get reset? How can I make the rejected phone show again?
    Thanks,
    Martin
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Re: If you reject a phone - where is the rejection list kept
    Rejected calls should be listed as received with zero duration.
  3. martinpluss
    Jun 28, 2011
    30
    Listed as received where? Is there a way of manually resetting this?
  4. nbailey
    nbailey Member
    Jan 31, 2011
    359
    Hi Martin,
    Good to see you again. When the phone gets rejected from the PNP process all you need to do is reset the phone (unplug it and plug it back in) and it should show up.
    Thanks,
    Nate
  5. eagle2
    Apr 27, 2011
    1,085
    11
    This is another topic about calls (not related to phones registration).
    Regards
  6. martinpluss
    Jun 28, 2011
    30
    Hey Nate,
    Thanks buddy. That's what I thought but unplugging and replugging the handset (Yealink T22P POE) didn't do it, and a factory reset on the handset Didn't help either.
    However if I plug a new handset into the same switch it pops up fine... even tried a reboot of the 3CX box.
    Very strange. So there isn't a session based list of 'rejected handsets' anywhere?
    Martin
    PS and what's the deal with all the spam in this forum? Looks like you have a firefight on your hands ;-)
  7. nbailey
    nbailey Member
    Jan 31, 2011
    359
    Yeah it is a fight, it goes through stages some days are better than others.
    As far as I am aware of there is not a list. When I do this what I do is unplug the phones, reset the services and plug them back in and for me that has worked. Give that a shot and let me know.
    Thanks,
    Nate
  8. martinpluss
    Jun 28, 2011
    30
    Sussed it. All my own fault. Haven't spotted the box I was installing on had a multihomed nic. Removed the 2nd (temp) IP and its all come right.
    Thanks for you time!
    M
