Ignoring Inbound Rules
Discussion in 'Windows' started by bweaver1985, Jan 16, 2015.
  1. bweaver1985
    Jan 16, 2015
    I have my 3CX setup with a generic sip trunk which created virtual port 10000.
    However all calls are being handled following those rules. Its ignoring all of my inbound rules. Is that a limitation of using a generic sip provider.
    Here are some logs:
    15-Jan-2015 21:31:01.863 [CM503012]: Inbound office hours rule (unnamed) for 10000 forwards to VM:1000
    15-Jan-2015 21:31:01.863 [Flow] Looking for inbound target: called=+19542788093; caller="WEAVER, BRIAN " <sip:954464****@:5060>
    As you see its seeing the correct incoming DID. But then it always finds the "Inbound office hours rule (unnamed) for 10000" this ignoring the inbound rules defined. 10000 is a remote connection created by the trunk when it was added.
  2. IliasL_3CX
    3CX Support
    Jun 2, 2014
    74
    Hi there,
    Can you kindly check the server activity log and see if you have a message that says adjust source identification. If this is the case then check the following link: http://www.3cx.com/blog/docs/source-identification-issues/
    Regards
  3. leejor
    10,366
    228
    I believe that this was already solved, something about a missing +1. The replies were part of the posts that disappeared over the weekend.
