IIS install on Server 08 R2
Discussion in '3CX Phone System - General' started by redhamilton, Jun 21, 2016.
  1. redhamilton
    Jan 22, 2016
    10
    Tried installing using IIS as webserver. Installer didn't put any files at all into the default IIS website. No files at all copied.
    Everything about the default IIS website is, well, default.
    \inetpub\wwwroot
    nothing there except the "welcome to IIS" files.
    I don't recall the installer giving and error messages.
    The abyss install worked fine. Obviously I'd rather not go that way with IIS available.
    Anyone else have this issue?
    -Josh
  2. redhamilton
    Jan 22, 2016
    10
    Update:
    Uninstalled everything/re-installed using same setup as before(same server, etc.)
    This time under "Default Website" I have:
    3CXCloudWebService Application
    A new website named "instance01" was automatically created with the following applications:
    ivr
    management
    MyPhone
    provisioning
    webrtc
    The correct bindings were installed to this site
    Cannot access management console.
    Installer was run as admin.
    I played around with permissions for both the Default website and new instance01.
    The common "IUSR" was not present.
    Adding IUSR with read rights got me from a site not accessible error to a blank page.
    Any help will be appreciated.
    -Josh
  3. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,325
    72
    Hey Josh, sorry if this is a silly question, but just to make sure, how are you trying to open the Management Console, by using "http://<local IP>/management/"?
    The reason I ask is because I believe in with Abyss you don't need the "/management" but for IIS you do.
