IIS management
Discussion in '3CX Phone System - General' started by etm_ltd, May 8, 2007.
  1. etm_ltd
    Nov 18, 2006
    69
    Because 3cx phone system using it own server (if I have understand), we can not access from our IIS localhost:5481 and directly manage the server.
    Does some has test to create a virtual folder from it IIS/W2003Srv to directly link, access and manage PHONE SYSTEM from anywhere?
    If so, can you give us result and the method you have used?
    Thx
  2. Anonymous
    Anonymous Guest
    Local host is used due to the way it installed.
    Unless you have the port allocated to another webserver/service you should be able to get it via:
    [your iis server]:5481
  3. Konrad
    May 6, 2007
    3CX using Apache HTTP Server and doesn't integrate with IIS.
