IIS port not propagated during install.
Discussion in '3CX Phone System - General' started by Henk, Nov 10, 2009.
  1. Henk
    Henk Member
    Nov 13, 2007
    250
    Not sure if it is an issue.
    When installing 3cx out of the box and not doing anything fancy all is ok. But me being me I want it different.
    I install 3cx on IIS, IIS is installed to use port 85 instead 80. All the web based items such as myphone and management consol are actually not using the port. (I also run apache, that is listening to port 80).
    Local host..... why use local host if I tell 3cx to install on eg 192.168.0.11, should the myphone and management console then point to that instead of localhost?
    Or did I do something wrong during install?
    Henk
