ilbc not available
Discussion in '3CX Phone System - General' started by adetterer, Oct 15, 2007.
  1. adetterer
    Aug 28, 2007
    22
    Hi Guys,
    Could someone please help me I have voip providers setup and I want to user ILBC however I only seem to have available G711-A/U Speex and GSM-FR.
    Is there something I am doing wrong? This is the same on two machines both with the latest version of 3CX.
    Thanks in Advance.
    Anthony D
  2. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    These are the free codecs used by 3CX, no others are available. Are you asking if more should be showing? They are looking into adding 729 as a paid add-on but no time specified as yet.
  3. adetterer
    Aug 28, 2007
    22
    3CX website says ILBC is available.... so why isn't it listed?
  4. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
  5. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    I think he means this one http://www.3cx.com/phone-system/enterprise-features.html
    Iblc its there alright, just not on any version of 3cx....
    Cheers
  6. adetterer
    Aug 28, 2007
    22
    Yep that's the one!
    So why isn't it an option in the list? Is there a way to enable it, IMO it is the ideal codec for the job.
  7. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    Never saw that :oops: Sorry.
    No clue. Maybe 3CX Staff will be kind enough to venture an answer?
  8. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    Does your provider support that one? For general info to help others looking for that who is it?
  9. adetterer
    Aug 28, 2007
    22
    Yes my provider does,
    Regardless though, it should be listed as an option even if the particular provider doesn't support it, because at that stage of the configuration the VOIP provider hasn't even been connected to yet.
  10. adetterer
    Aug 28, 2007
    22
  11. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Better wait for an answer from the 3CX team, i guess no one knows why there isnt the iBlc option on 3cx....
    Cheers
  12. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    I am sure its not an option in the present 3CX release though I have no explanation why it was described as such on their site. 3CX staff will have to answer that for you but with v4 set to be released in Alpha or Beta any time now, you may have a bit of a wait for an answer, they are quite busy. And v4 may also solve this issue, no clear info on it as yet.
