Import backup v9 to v10 during install**SOLVED ACCESS PROB
Discussion in '3CX Phone System - General' started by bluetel2, Mar 23, 2011.
  1. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    8
    very good plaisure to see v10 will plublish. nice work team.
    I try to import backup from v9 and it's write "this is not supported backup"... it's from 2003 to xp... since installation wizard.
    maybe it's because beta version... ?
    tks
  2. Welzo
    Nov 11, 2010
    12
    Re: Import backup v9 to v10 during install
    I had no problem doing backup of our live 3CX v9 and then import it at the installation of v10 on another (test) server.
  3. nb
    nb Support Team
    Jun 7, 2007
    2,147
    173
    Hi Bluetel - It cannot be - something very strange - we want to see it.
    Can you send us the backup? Go on V9 and take a backup without prompts and no voicemails nothing at all.
    nb@3cx.com or upload somewhere like usual
  4. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    8
    Hi Nicky
    well it's stupid error. is on share disk and from server i have not rights, and new 3cx server said this error message, but when i try with backup and restore, it said error accès...
    sorry for distub
  5. nb
    nb Support Team
    Jun 7, 2007
    2,147
    173
    Dont worry - you have me a fright.
    So it is an access problem right? To make sure copy the backup to the local disk and try and restore from there.
  6. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    8
    Yes i do it like this and it worked. I was deceived by the generic message when import existing PBX during install.
    tks Nicky
