Import Company Phonebook Encoding
Discussion in '3CX Phone System - General' started by JanW, Dec 10, 2009.
  1. JanW
    Sep 18, 2009
    5
    I'm trying to import our company phone book from a csv.
    All goes well except the encoding seems to be a problem.
    The letters àéè become a square.
    If I edit the names in the webinterface after import and change them, the character is shown perfect.
    Does the csv file need some sort of encoding?
    Kind regards,
    Jan
