Solved Import CSV contact files
Discussion in '3CX Phone System - General' started by ltifoski, Sep 13, 2017.
  1. ltifoski
    Jul 29, 2017
    38
    Dear,
    I try import the csv file with my contacts in 3CX phone system 15. But i get error stating that the mobile column is missing. However, it is correct and unrecognized. Can you help me?
    Thank you.
    Lucas Tifoski.
  2. AndreasPo_3CX
    AndreasPo_3CX Support Team
    Aug 10, 2017
    138
    12
    Hello @ltifoski ,
    Can you post a sample of your csv with sensitive information changed? Make sure to include the column headers.
  3. ltifoski
    Jul 29, 2017
    38
    This is a example:
  4. AndreasPo_3CX
    Aug 10, 2017
    138
    12
    From the screenshot it looks fine, although I meant that you could paste it as text here so i can try it.
    What you could try though is the following:
    1. Add a dummy contact through the management console
    2. Export contacts
    3. Open the exported file and paste your contacts in that file
    4. Try importing that file and see if it is accepted
    This will ensure that the column header format is correct.
  5. ltifoski
    Jul 29, 2017
    38
    I've tried it this way and it did not work. Is there any other way?
  6. ltifoski
    Jul 29, 2017
    38
  7. AndreasPo_3CX
    Aug 10, 2017
    138
    12
    @ltifoski
    I have sent you a PM, please check your inbox.
  8. ltifoski
    Jul 29, 2017
    38
    Dear!
    I solved the problem:
    The problem is; in the .csv file when it should only be,
    I solved the problem by opening the file with notepadd ++ and substituting; per ,
  9. AndreasPo_3CX
    Aug 10, 2017
    138
    12
    Glad the issue is resolved!
