Import CSV Format
Discussion in '3CX Phone System - General' started by tjabaut, Oct 17, 2007.
  1. tjabaut
    tjabaut New Member
    Jul 24, 2007
    123
    Hi all,
    I am trying to use the CSV import for a large number of extensions, but I am having trouble finding info on the exact format.
    Does anyone have it?
  2. BendyMetal
    Oct 8, 2007
    36
    <<Extension number>>, <<First Name>>, <<Last Name>>, <<Authentication ID>>,
    <<Authentication password>>, <<Outbound Caller ID>>
    user guide, page 27 - i needed this too! glad i looked for it!!
    :D
  3. tjabaut
    tjabaut New Member
    Jul 24, 2007
    123
    I do not see it on page 27.
  4. BendyMetal
    Oct 8, 2007
    36
    must have a different manual then....definitely there.
