Import / Export All Settings
Discussion in 'Windows' started by rscl.mumbai, Dec 8, 2010.
  1. rscl.mumbai
    Jul 22, 2010
    8
    Is there any way to export / import all the settings ?
    This will really help me to backup by settings and restore them in case of h/w crash or change in laptop.
    Thx in advance.
    Sanjay
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    if you goto Start Menu / All Programms / 3CX Phone
    you shoulld see a option for Backup and Restore Tool
  3. rscl.mumbai
    Jul 22, 2010
    8
    Thx dave, but could not find the option you referred to.
    See attached screenshot. Anything I am not seeing ?
    Thx
  4. davidbenwell
    Apr 27, 2010
    704
    Hi, if you are on the PC / Server where you installed 3CX Phone System
    you should see a folder "3CX Phone System" under Start Menu / Programes (All Programms)
