import/export BLF keys template?
Discussion in 'Windows' started by Anotaris, Nov 9, 2015.
  1. Anotaris
    Nov 9, 2015
    i am using v14 sp1 with 3CXPhone app for windows.
    i also made for one extension the virtual BLF Keys. it works great!
    but now i would like to use this template for the other extensions too.
    So, Is there a way to export, import, or copy this template to the other extensions?
    Best regards,
  2. Charles_3CX
    Charles_3CX New Member
    3CX Support
    Jul 6, 2015
    114
    HI
    You can select all the extensions from the 3CX Management console, under the Extensions node, then configure the BLF keys for all your extensions at the same time.
