Import / export Inbound / outbound rules
Discussion in 'Ideas' started by jeroendebruijn, Jan 31, 2018.
  1. jeroendebruijn
    Nov 9, 2015
    35
    16
    In the Netherlands, they Government dial plan for public phone numbers is kind a messy. If you would do it exactly right, you need to have a dozen or more rules created to comply with the actual number plan.
    And i expect other countries not being much better. In that way, it would be useful to have at least an import / export of outbound rules,
    I would not mind to have change the outgoing trunk to the right ones after export, (e.g.) it would be fine if the outbound rules just were put to use the first available trunk)
  2. Daniel Bezuidenhout
    Feb 21, 2018
    I had a team of data capturers capture over 700 Outbound rules, seeing I was told to use this feature for speed dials. I would like to find out if there is a means of exporting these to .csv.
