Import From Active Directory
Discussion in '3CX Phone System - General' started by ntnetzeband, May 26, 2017.
  1. ntnetzeband
    Jul 30, 2016
    65
    5
    Does anyone know of a way to only import users from Active Directory? When I connect through LDAP, it gets all of my computer objects as well even though I tell it to only query the User Object class.
  2. Charles_3CX
    Charles_3CX New Member
    3CX Support
    Jul 6, 2015
    114
    Hi There
    Within Active Directory Computers have the tag 'User' within their ObjectClass. This can be seen from ADSI edit when locating a computer and looking at its properties, Under OjectClass you will also see it as 'User:Computer, Thus when searching AD from the extensions section computers will also show up, there is no way to avoid this.
