Import Users Contacts to 3CXPhone
Discussion in 'Windows' started by ckatterl, Dec 15, 2016.
  1. ckatterl
    Nov 15, 2016
    55
    6
    Hi there,
    (how) is it possible to import a users private contacts into 3CXPhone from CSV, xls etc?
    BR, Christian
  2. ALuisPV
    Mar 7, 2016
    28
    Hi ,
    as far I know, you can import contacts to 3CX Phone in Windows from an Office 365 account or from a Google Account.
    One solution can be to use a Google Account and import all the contacts to this Google Account. Then, you can import contacts from Google to 3CX Phone in Windows.
    Best Regards.
  3. ckatterl
    Nov 15, 2016
    55
    6
    I tried that, but contacts from google are only shown. I cannot export them (for later import) or move them....
  4. ckatterl
    Nov 15, 2016
    55
    6
    Maybe it's an idea to use the outlook connector. I am not a fan of handing over personal data to google. Otherwise - when i would tell my collegue to import her 1.800 contacts manually, - she would get a heart-disease ;-)
  5. ckatterl
    Nov 15, 2016
    55
    6
    Just to ask again - does someone know, if there's a way to import contacts into the 3CX Phone App for Windows (for example via CVS..)?
    BR, Christian
  6. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    29
    Yes, there is a way. You can use the API to create an import script. And if someone has already done it, let me know as I know it too
  7. Virutas3CX
    Sep 8, 2016
    5
    Anybody knows which folder allocates personal contacts you add to the 3CXPhone (Windows)? I've been searching on Windows folders (appdata, documents and settings, etc) but I cannot find anything. We want to export personal book to an CSV or similar.
  8. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    29
    Must be in some database
