Importing DID / DDI numbers
Discussion in '3CX Phone System - General' started by messedupmojo, Apr 10, 2012.
  1. messedupmojo
    Apr 7, 2012
    We have an implementation of 400+ users, it appears that you can import user details - but im not sure if you can import an initial list of DID / DDI numbers - we have over 400 to setup
    Is this included in the user import - or is there a separate import for DID/DDI's?? (or no import at all??)
    David
  2. netswork
    netswork Active Member
    Mar 11, 2011
    577
    You import the users with the spreadsheet but I have not imported DID's. I can see where that would be an issue having to do as many as you.
    Following this thread in case someone has an answer.
