importing voicemail post server rebuild
Discussion in '3CX Phone System - General' started by technology7, Jun 5, 2012.
  1. technology7
    Dec 28, 2009
    11
    We are going to change over a 3cx server form 5 to 3 digit extensions which is basically meaning a complete rebuild of the server. We are wondering if/what would be the procedure to import the existing voicemail from the old 5 digit extension server into the new corresponding 3 digit extension server. Has anyone ever tried this? Is there an approved method? Thanks!
  2. efounco
    efounco New Member
    Sep 28, 2011
    148
    If I'm not mistaken you can simply go into the Advanced Settings\Custom Parameters and change ENL from 5 to 3. From there, you'll need to modify the system extensions and user extensions accordingly. You don't have to "rebuild" the entire server if you don't want to...
    Also, voicemail messages are strored in:
    c:\ProgramData\3CX\Data\Ivr\Voicemail
    Simply backup that folder and you have a copy of all the voicemail messages stored on the system...
