impossible to auto provision Yealink T21 E2
Discussion in '3CX Phone System - General' started by Tomtom78, Aug 23, 2017.
  1. Tomtom78
    Aug 23, 2017
    factory reset of the phone = done
    config of the extension = done
    When pressing Autoprovision Now from the webinterface of the phone two things can happen:
    1) after a while the page refresh and nothing is done
    2) on the phone display appers "redirect - user name" i enter admin as default of the phone or the extension number ... after some try the ip is banned
    no way to autoprovision. please help
  2. that1guy
    Jul 27, 2017
    48
    Are you using FQDN or IP address to auto provision? Is the phone in office or remote?
  3. Tomtom78
    Aug 23, 2017
    The phone is in remote and I am using IP... now, after one night the phone appears registered and works however online appears as: UNPROVISIONED
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
    How did you provision the phone? Did you use RPS, copied the provisioning link into the phone or did you manually provision the phone?
