Improve Gigaset DECT provisioning
Discussion in 'Ideas' started by tvdir, Nov 10, 2017.
Improve Gigaset DECT provisioning 4.5 5 4votes
4.5/5, 4 votes
  1. tvdir
    Feb 17, 2017
    68
    15
    Glad to see that both the N510 and N720 are supported.
    I'd like to suggest some improvements in the provisioning process:
    - Corporate Directory: the Gigasets have the ability to load an XML directory, just like Yealink, Snom,... just a slightly different format.
    - Display name is always the extension. Shouldn't be too difficult to change this to first and last name.
    - Being able to change other settings such as disabling info services, calendar button,...
    Other suggestions are welcome!
    HH60 likes this.
