Solved Improvements to iOS Chat
Discussion in 'iOS' started by tomnorton, Nov 14, 2017.
  1. tomnorton
    Feb 23, 2015
    21
    Would it be possible to get 2 improvements to the iOS chat:
    • When you get a chat notification, can you get taken directly to the chat when you swipe it? At the moment it goes to the dialer.
    • The keyboard experience does not feel like other chat apps on iOS. For example the initial letter on a word in a sentence doesn't get capitalised like on other apps. Can that be addressed?
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,416
    61
    For released 15.2.7.222, but also for latest beta:
    1 - if you tap a chat notification (no matter device is locked or not) it is first shown the dialer, then the Chats window. If the device is locked and you swipe the notification left and choose View, the whole message will be shown. To go straight to the particular chat conversation is not possible for now, because the sender might be part of the single chat, but also member of different group chats, and the current implementation of the PBX does not provide a "chat room" info.
    2 - Capitalization is a device setting. Either long press the globe button of the keyboard, or check device's Settings/General/Keyboard/Auto-Capitalization option.
    Hope it helps.
    vali
