in a LIVE small business environment
Discussion in '3CX Phone System - General' started by giovanni0826, Jun 22, 2007.
  1. giovanni0826
    Apr 6, 2007
    53
    I would like to hear some cases where the 3cx pbx was actually put in a live small business environment that wasn't owned or ran by a relative. and what end device was used (i.e. softphone, Grandstream...) I just curious. And what country
  2. Anonymous
    Anonymous Guest
    Country: Australia
    Company: funny enough, Dutch Digital Dynamics
    Owned: Well by me :).
    Offices: 3 remote sites one PBX all on same network segment (as I own the network infrastructure between the offices)
    Employees: Depending on type of project can range from 3 up to 200+
    Equipment:
    Server: Dell PowerEdge (servicing multiple apps including 3CX)
    Switch: Netgear smart switches
    Routers: Billion, DLink (wired and wireless).
    Network: Mixture of 8Mbs, 54Mbs, 100Mbs, 1000Mbs.
    Phones: AT530, AT530P and HP 6965 (SIP and WiFi currently under review)
    ATA: Lynksys (is there any other? :) One pstn line, one DID line seem that is all we need as we do a lot of mobile phone traffic. We are investigating a GSM gateway posibility into 3CX.
    Traffic type: VoIP, Video and Data
    Traffic control: QoS, ToS.
    Average phone calls: approx 20 ph (and increasing now i am spending some time with 3CX). Switching between PSTN and DID, not including Mobile.
    There are several businesses here in AU currently in the process of implenting or building upon the 3CX software. Commercial confidentiality restricts me too name them.
    If they are on the forum they can speek for them self.
    If you looking for some references if this application is able to work in a real environment. Well we run everything through 3CX and we have not had any problems. So from my point of view the application is small business ready, enterprise will not be long from now but I would not recommend that as yet simply because i have not done a load test on the application so I cannot recommend what I do not know. :).
  3. DaKhalli
    DaKhalli New Member
    Jun 2, 2007
    122
    Country: The netherlands
    company: notomato B.V.
    maintained: by me
    employees: 15
    Hardware: The 3cx boxhas its own server. a celeron 2 ghz 512 mb ram. Work perfectly now i got the settings right.
  4. giovanni0826
    Apr 6, 2007
    53
    Are you using softphones? How many Providers do you have... is it a DSL connection.
  5. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    AT China HKSAR
    1 3CX PBX
    1 Local gateway (4 x PSTN Line)
    1 Remote gateway (VPN, 4 x PSTN Line)
    1 Remote gateway (NAT, 1 x PSTN Line)
    10 Hard Phone (Local LAN)
    5 Soft Phone (NAT, 4 Local and 1 China Mainland)
    4 Remote hard phone (NAT)
    1 Hard Phone at Thailand (VPN)
    2 Hard Phone at China Mainland (VPN)
  6. giovanni0826
    Apr 6, 2007
    53
    NICE! whats your calls per/hr? any issues with the config setup? whats your hardware in the pbx i.e. Memory, Processor....
  7. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Hardware: The 3cx box has its own server. HP P4 2.8 ghz 512 mb ram. Works fine. Not too much call at the same time. We hit max. around 4 concurrent at the same time.
    Sound quality perfect with Ploycom hard phone. For softphone it will be Eyebeam.
    Gateway is using Welltech WG3804A, Audio Code MP-114, DLINK DVG7022S and Grandstream HT-488.
    No big issue found before. Only Grandstream HT-488 under NAT seems not stable, it may be our ISP issue.
    We will test T1/E1 line soon. 200 PSTN number and 23 concurrent calls.
  8. DaKhalli
    DaKhalli New Member
    Jun 2, 2007
    122
    we use a mix of granstream 2000's with linksys ata's and one softphone, all works great audio quality perfect (mutch better then on asterix)
    i would say go for it :)
  9. Anonymous
    Anonymous Guest
    Country: USA
    Maintained by: Jaydien Network Solutions
    Runs on: P4 w/ 1 GB RAM
    Voicemail: Integrated with Excahnge 2007 for voicemail
    Phones: 5 Linksys SPA962
    PSTN Gateway: SPA400
    The system works flawlessly! Perfect voice quality and very stable and reliable.
    Brian
    http://www.jaydien.com
  10. Anonymous
    Anonymous Guest
    Lol, about time (Just kidding).
    Looks like you got the setup i think is one of the better ones. Good stuff.
    Your exchange integration, is that full eg you use the Exchange IVR or only the voice mail bit.
