IN/CALL using Beronet BFSB 2XO
Discussion in 'Windows' started by ssnickson, Oct 1, 2015.
  1. ssnickson
    Oct 1, 2015
    Dear All,
    I m new to use 3CX, i have setup a small PBX system at home for testing. i have installed 3CX at 3 Android phone and 1 Yealink IP Phone. Internal setup is working fine with assigned extension. I want to establish a IN/OUT bond telephone calls using Beronet BFSB 2XO. I have setup the Getaway according to the step by step instruction given in 3CX website(http://www.3cx.com/docs/pstn-lines-voip-gateways/). When i make a call from an extension i can hear a ring tone and also i can see in the Trunk/Line status that there is an Outgoing call. But i m not receiving call to my mobile. I m wondering is the correct model to use or is there any additional setup need to be done?
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Hi there,
    I would suggest to review your dial plan in the beronet and also to enable dial plan debug to have more information on the call status as from the pbx it seems that the call goes fine to the gateway.
