inbound call disconnects after 32
Discussion in '3CX Phone System - General' started by liptinfor, Dec 27, 2011.
  1. liptinfor
    Dec 27, 2011
    6
    I have a problem that my SIP inbound call disconnects after 32 sec. I do not have any issue with the outbound call but for the SIP number i have this problem.
    I have talked with my SIP provider he told me that there is a problem in the 3CX cause when the call disconnect the SIP BYE message is shown.
    If i am bypassing the 3CX and connect the phone directly with static ip i do not get any problem
    The log is
    you can see in the last the SIP BYE message.
    ### sendto 81.199.131.11:1064 712 bytes @ Mon Dec 19 11:59:00 2011
    INVITE sip:9710899086@81.199.131.4:5060 SIP/2.0
    From: sip:19736225024@216.53.17.97:5060;user=phone;tag=ccid-15110674-535889426
    Contact: sip:19736225024@216.53.17.97:5060
    Via: SIP/2.0/UDP 216.53.17.97:5060;branch=z9hG4bK-535889426-1
    To: <sip:9710899086@81.199.131.4:5060>
    User-Agent: Net2Phone SIPCERT
    Call-ID: 20111219115900-759-089@216.53.17.97
    CSeq: 1 INVITE
    Max-Forwards: 70
    Allow: ACK,BYE,CANCEL,INVITE,OPTIONS
    Content-Length: 233
    Content-Type: application/sdp
    v=0
    o=535889426 15110674 15110674 IN IP4 213.166.104.153
    s=SIP Call
    c=IN IP4 213.166.104.153
    t=0 0
    m=audio 20018 RTP/AVP 18 0 101
    a=rtpmap:18 G729/8000
    a=rtpmap:0 PCMU/8000
    a=rtpmap:101 telephone-event/8000
    a=fmtp:101 0-15
    ### sendto 81.199.131.11:1064 712 bytes @ Mon Dec 19 11:59:02 2011
    CSeq: 1 INVITE
    Max-Forwards: 70
    Content-Length: 233
    v=0
    s=SIP Call
    t=0 0
    a=fmtp:101 0-15
    ### sendto 81.199.131.11:1064 712 bytes @ Mon Dec 19 11:59:04 2011
    CSeq: 1 INVITE
    Max-Forwards: 70
    Content-Length: 233
    v=0
    s=SIP Call
    t=0 0
    a=fmtp:101 0-15
    ### recvfrom 81.199.131.11:1064 388 bytes @ Mon Dec 19 11:59:05 2011
    SIP/2.0 180 Ringing
    Contact: <sip:9710899086@81.199.131.4:5060>
    To: <sip:9710899086@81.199.131.4:5060>;tag=400e8330
    From: <sip:19736225024@216.53.17.97:5060;user=phone>;tag=ccid-15110674-535889426
    CSeq: 1 INVITE
    User-Agent: 3CXPhoneSystem 10.0.19079.0
    Content-Length: 0
    ### recvfrom 81.199.131.11:1064 388 bytes @ Mon Dec 19 11:59:06 2011
    SIP/2.0 180 Ringing
    CSeq: 1 INVITE
    Content-Length: 0
    ### recvfrom 81.199.131.11:1064 388 bytes @ Mon Dec 19 11:59:08 2011
    SIP/2.0 180 Ringing
    CSeq: 1 INVITE
    Content-Length: 0
    ### recvfrom 81.199.131.11:1064 781 bytes @ Mon Dec 19 11:59:21 2011
    SIP/2.0 200 OK
    Contact: <sip:9710899086@81.199.131.11:1096>
    CSeq: 1 INVITE
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
    Supported: replaces
    Content-Length: 250
    v=0
    o=3cxPS 226492416000 273233739777 IN IP4 81.199.131.11
    s=3cxPS Audio call
    c=IN IP4 81.199.131.11
    t=0 0
    m=audio 9042 RTP/AVP 0 101
    a=fmtp:101 0-15
    a=sendrecv
    ### sendto 81.199.131.11:1096 343 bytes @ Mon Dec 19 11:59:21 2011
    ACK sip:9710899086@81.199.131.11:1096 SIP/2.0
    Via: SIP/2.0/UDP 216.53.17.97:5060;branch=z9hG4bK-535889426-2
    CSeq: 1 ACK
    Max-Forwards: 70
    Content-Length: 0
    ### recvfrom 81.199.131.11:1064 781 bytes @ Mon Dec 19 11:59:22 2011
    SIP/2.0 200 OK
    CSeq: 1 INVITE
    Supported: replaces
    Content-Length: 250
    v=0
    s=3cxPS Audio call
    t=0 0
    a=fmtp:101 0-15
    a=sendrecv
    ### recvfrom 81.199.131.11:1064 781 bytes @ Mon Dec 19 11:59:24 2011
    SIP/2.0 200 OK
    CSeq: 1 INVITE
    Supported: replaces
    Content-Length: 250
    v=0
    s=3cxPS Audio call
    t=0 0
    a=fmtp:101 0-15
    a=sendrecv
    ### recvfrom 81.199.131.11:1064 781 bytes @ Mon Dec 19 11:59:33 2011
    SIP/2.0 200 OK
    CSeq: 1 INVITE
    Supported: replaces
    Content-Length: 250
    v=0
    s=3cxPS Audio call
    t=0 0
    a=fmtp:101 0-15
    a=sendrecv
    ### recvfrom 81.199.131.11:1064 781 bytes @ Mon Dec 19 11:59:40 2011
    SIP/2.0 200 OK
    CSeq: 1 INVITE
    Supported: replaces
    Content-Length: 250
    v=0
    s=3cxPS Audio call
    t=0 0
    a=fmtp:101 0-15
    a=sendrecv
    ### recvfrom 81.199.131.11:1064 781 bytes @ Mon Dec 19 11:59:44 2011
    SIP/2.0 200 OK
    CSeq: 1 INVITE
    Supported: replaces
    Content-Length: 250
    v=0
    s=3cxPS Audio call
    t=0 0
    a=fmtp:101 0-15
    a=sendrecv
    ### recvfrom 81.199.131.11:1064 781 bytes @ Mon Dec 19 11:59:48 2011
    SIP/2.0 200 OK
    CSeq: 1 INVITE
    Supported: replaces
    Content-Length: 250
    v=0
    s=3cxPS Audio call
    t=0 0
    a=fmtp:101 0-15
    a=sendrecv
    ### recvfrom 81.199.131.11:1064 781 bytes @ Mon Dec 19 11:59:52 2011
    SIP/2.0 200 OK
    CSeq: 1 INVITE
    Supported: replaces
    Content-Length: 250
    v=0
    s=3cxPS Audio call
    t=0 0
    a=fmtp:101 0-15
    a=sendrecv
    ### recvfrom 81.199.131.11:1064 461 bytes @ Mon Dec 19 11:59:52 2011
    BYE sip:19736225024@216.53.17.97:5060 SIP/2.0
    Via: SIP/2.0/UDP 81.199.131.11:1064;branch=z9hG4bK-d8754z-7c4d0a740b61e774-1---d8754z-;rport
    Max-Forwards: 70
    To: <sip:19736225024@216.53.17.97:5060;user=phone>;tag=ccid-15110674-535889426
    From: <sip:9710899086@81.199.131.4:5060>;tag=400e8330
    CSeq: 2 BYE
    Content-Length: 0
    ### sendto 81.199.131.11:1064 353 bytes @ Mon Dec 19 11:59:52 2011
    SIP/2.0 200 OK
    Via: SIP/2.0/UDP 81.199.131.11:1064;branch=z9hG4bK-d8754z-7c4d0a740b61e774-1---d8754z-;received=81.199.131.11;rport=1064
    CSeq: 2 BYE
    Content-Length: 0
    ### recvfrom 81.199.131.11:1064 461 bytes @ Mon Dec 19 11:59:53 2011
    Max-Forwards: 70
    CSeq: 2 BYE
    Content-Length: 0
    ### sendto 81.199.131.11:1064 353 bytes @ Mon Dec 19 11:59:53 2011
    SIP/2.0 200 OK
    CSeq: 2 BYE
    Content-Length: 0
    11,126
    330
    Run the 3CX firewall checker, see if it comes up with any issues, that may require resolving, on your router.
  3. liptinfor
    Dec 27, 2011
    6
    I have also checked the firewall all things are passed.
  4. leejor
    11,126
    330
    SIP 200 messages are being sent repeatedly because the far end is probably not receiving an ACK (router setting?), then the call is dropped.
  5. liptinfor
    Dec 27, 2011
    6
    so what i do?
  6. leejor
    11,126
    330
    You can confirm that it is your router by either replacing it with another make (you don't say what type you are using), or by bypassing it completely, by allowing the computer running 3CX, to pick up a public IP (no NAT).
    If that works then you need to work on your router. There is a possibility that there is a firewall programme at work too. Everyone's set-up is different, there is no one solution to NAT issues.
  7. liptinfor
    Dec 27, 2011
    6
    I am using cisco 1841 for the nat after that the sever is installed. I connect the phone directly with the same nat network ip bypassing the sever it do not disconnected. But when i am connecting the sever it is disconnecting. The is no issue with the router i checked the ports and all.
  8. leejor
    11,126
    330
    Hopefully there is someone here that is more familiar with the hardware you are using, and can offer some suggestions. It may be a very simple setting that is incorrect.
    Other than that, your best be would be to contact a VoIP company/dealer in your area that supports 3CX, or perhaps a support contract, with 3CX directly.
    I'm not sure if any if these troubleshooting/configuration articles are of any help.
    http://www.3cx.com/blog/tag/troubleshooting/
    http://www.3cx.com/blog/voip-howto/cisco-voip-configuration/
  9. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    The problem is not related to Cisco router. I can confirm that Cisco is working fine (of course if not misconfigured).
    The timeout of 32 seconds is most probably a setting of your provider.
    I would advise not to use STUN in your 3CX server behind a Cisco router (Cisco is supporting SIP ALG correctly and makes no sense to disable SIP ALG). You need to set port forwarding only and make sure the firewall checker is passing successfully (exit code = 0).
    Regards
  10. liptinfor
    Dec 27, 2011
    6
    Can you help me how to use the port forward in Cisco my 3cx server ip is 10.10.10.205
    yes all firewall checker are already passing.
  11. eagle2
    Apr 27, 2011
    1,085
    11
    I've set your internal address 10.10.10.205. 'FastEthernet4' is the name of the WAN connection, could be necessary to be modified before applying the configuration to router.
    Kind regards
  12. liptinfor
    Dec 27, 2011
    6
    thanks for that can you please let me know fastethernet4 means my interface of the wan? that is public ip interface??
  13. eagle2
    Apr 27, 2011
    1,085
    11
    in my router FastEthernet4 is the WAN interface (Ethernet), depends on your model (you may have different type or number of interfaces). Also if you have set a fixed IP address (public address) to WAN interface, you may use that address too instead of the name of the interface.
    If you like send me a private message with more details about your configuration, I could tell you more about.
    Regards
  14. johnp@vvmicro.com
    Dec 30, 2011
    The problem may be SIP ALG on your Cisco router. Disable SIP ALG or SIP fixup and try an inbound call again. I had a problem with a Netgear N300 with SIP ALG enabled doing the same thing. Disabling SIP ALG allowed me to make calls as normal.
