Inbound call generates busy signal
Discussion in '3CX Phone System - General' started by kflorian, Dec 30, 2016.
  1. kflorian
    May 11, 2008
    17
    A few days ago I discovered that my Vitelty account had been compromised.
    I deleted the existing subaccount and created new subaccount.
    I added an IP Address endpoint in Vitelity (I know, it should have been there from get-go)
    The PBX correctly registers with Vitelity and I can make outbound calls but all inbound calls generate a busy signal.
    I made no changes on 3CX server and I'd never set anything on my router...it "just worked" when I installed 3CX a few months ago.
    What did I break and how do I fix it?
    Ken
  2. kflorian
    May 11, 2008
    17
    okay...step one accomplished!...update routing method in Vitelity but now I'm getting the "We received 'CONGESTION' which usually means your server or device does not recognize the number being dialed."
  3. leejor
    11,117
    329
    I would check the 3CX Activity log for error messages.
