Inbound Call Identification
Discussion in '3CX Phone System - General' started by information6, Mar 16, 2016.
  1. information6
    Aug 9, 2010
    I have a client using 3CX that is starting a few companies. They would like to identify the respective companies primary number so the receptionist can determine which of the companies was being called so they can greet the caller respectively. The owner only allows the DR to be used for overflow, so the receptionist always answers calls directly during business hours. Any suggestions?
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,311
    249
    The name of the inbound caller id shows up on the display. You can prepend (before the number COMP A:4805551212) or append (after the number 4805551212:COMP A).
    I find however that the handset lookup on the internal phonebook will over write this. Usually we only have employees in the phonebook anyhow.
    It used to be a menu option - but perhaps now only in Parameters:
    APPENDCIDQUEUE
    PREPENDNAMETOCID
  3. information6
    Aug 9, 2010
    Thanks Craig. To clarify, we are not looking for CID, but the number the caller called in to so the receptionist can identify which line/company the party is trying to reach.
  4. craigreilly
    Feb 1, 2012
    3,311
    249
    YES - so the NAME of the DID they called is displayed.
    So for our Main line - we have MAIN - 4805551212. For our 800 # we show 800# - 4805551212, etc. (the 4805551212 being their caller id and the Name being my system number that they called)
    Or you can print the number (just name the DID the same as the number) but this would likely be confusing.
    6025551212 - 4805551212 where the 602 would be the number they called and the 480 being their number.
  5. hogan71088
    Nov 30, 2015
    60
    Where exactly is this set up?
  6. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,083
    61
    You apply a name to the inbound rules and/or ring group/queue.
