Inbound call interrupts dialing on Aastra phone
Discussion in '3CX Phone System - General' started by GtInNoVaTiOn, Mar 13, 2016.
  1. GtInNoVaTiOn
    Mar 9, 2016
    13
    Anyone have any solution? Have 3CX v14SP3 with Aastra 6755i. If I am dialing a number and a call comes into the ring group the phone rings and I have to press Ignore then dial the entire number again. I have tried firmware from 2011-2016 with no luck. There is a setting in the phone for "Incoming call interrupts dialing" but it is disabled.
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    64
    My guess, and it is a guess, is probably not. I am thinking that the issue is that when inputting the numbers for the dial string, the phone is operating independently of 3CX and therefor the system is not aware of the phone being in use and will send the call to the extension. As the phone has not actually initiated the call (only input of numbers), the phone is not "busy" and will ring. It becomes busy when in a call or DND buttons are engaged. The DND may be dependent on whether its code was programmed to match that of 3CX of it a code is being used to set DND at 3CX If not, the call may still be sent to the phone whereupon the phone may chirp upon receiving the call before it can send the busy response back as a result of the DND. If set at 3CX, then the system will not try and send to the extension as it is already aware of the extension being busy.
    The setting you mention in the phone may need to be used in conjunction with some other attribute, so I can only suggest that you get the admin manual for same and see how that function is intended to work. Otherwise, you might need to contact Aastra's support for the answer.
  3. GtInNoVaTiOn
    Mar 9, 2016
    13
    Thanks for the reply, by the way this was prev. a trixbox pro system with these phones and it did not have this problem.
  4. GtInNoVaTiOn
    Mar 9, 2016
    13
    I figured it out. In case anyone else has this problem, in the Aastra, Live Dialpad needs to be On which auto selects a line when dialing so that incoming calls and paging do not interrupt.
