Inbound call routing issue
Discussion in '3CX Phone System - General' started by jeff yager, Oct 10, 2012.
  1. jeff yager
    Oct 10, 2012
    17
    I am using 3cx 11 with 2 incoming DID's via NexVortex. Here is the scenario I need to accomplish:
    My company has two seperate companies. I need to be able to route each of the 2 did's to seperate Line appearances based on DID that was called. For instance, Company A is 555-555-1212, company B is 555-555-1213. If someone calls Company A it needs to route to Digital receptionist A, If someone calls company B, it needs to go to Digital receptionist B.
    And when caller makes their choice the exetension selected needs to know which company the call is for.
    Can Anyone help with this?
    Thank you!!
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,061
    56
    Set up the DID numbers under VOIP provider. Then set-up "Inbound Rules" using the DID/DDI Number mask option and point each to their respective DR/IVR for that company. You can label the rules CoA and CoB (in inbound rules) which can also show in the caller-ID so the extension ultimately being reached will know for which company the call was placed.
  3. jeff yager
    Oct 10, 2012
    17
    Thank you, working on it now. Not sure where to set caller id on a did.
  4. lneblett
    Sep 7, 2010
    2,061
    56
    See attached.
    Fax *4910 will show in the caller ID as will the originators true caller-id. The downside is that it may be somewhat dependent on phone display capability. So, sub CoA for FAX.
  5. 3CXfoxhallsolutions
    3CXfoxhallsolutions New Member
    Sep 8, 2012
    211
    Also useful to know about this page in the VoIP Provider set up ...
    http://www.3cx.com/blog/docs/did-voip-provider/
