Inbound call won't connect
Discussion in '3CX Phone System - General' started by HughNZ, May 11, 2011.
  1. HughNZ
    May 11, 2011
    Hi Everyone,
    Hoping you can help with an issue I have here. I think it may be after applying the latest service packs, inbound calls no longer work. I am running 3CX version 9, was on SP3, now on SP5a. My set up is as follows:
    POTS phone line --> Linksys SPA3102 (10.5.1.3) --> 3CX (10.5.1.5) --> Linksys SPA2102 (10.5.1.4) --> Analogue phone
    If I set the incoming call on the POTS line to go direct to my extension (101), it just keeps ringing. Here are the logs:
    Code:
    421  [CM503016]: Call(19): Attempt to reach <sip:101@10.5.1.5:5060> failed. Reason: Not Acceptable HereReason Unknown
    22:33:57.406  [CM503003]: Call(19): Call to sip:101@10.5.1.5 has failed; Cause: 488 Not Acceptable Here; warning: Media type not available; from IP:10.5.1.4:5060
    22:33:57.375  [CM503025]: Call(19): Calling Ext:Ext.101@[Dev:sip:101@10.5.1.4:5060]
    22:33:57.328  [CM503004]: Call(19): Route 1: Ext:Ext.101@[Dev:sip:101@10.5.1.4:5060]
    22:33:57.328  [CM503010]: Making route(s) to <sip:101@10.5.1.5:5060>
    22:33:57.328  [CM505002]: Gateway:[Phone Line] Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA3102-5.1.10(GW)] PBX contact: [sip:10000@10.5.1.5:5060]
    22:33:57.312  [CM503001]: Call(19): Incoming call from 288997890@(Ln.10000@Phone Line) to <sip:101@10.5.1.5:5060>
    If a call comes in via a VOIP line, it works fine. Its only a problem coming through the POTS line on the Linksys SPA3102.
    Any help would be greatly appreciated.
    Cheers, Hugh.
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    The quickest way to resolve this is to do a reset of the Linksys SPA3102 and get 3CX to provision it and see if that sorts it out.
  3. leejor
    10,758
    286
    Codec issue?
  4. davidbenwell
    Apr 27, 2010
    704
    thats what i thought, but it should default to g711 unless changed by the user
  5. HughNZ
    May 11, 2011
    Re-provisioning the SPA3102 worked. Thanks for your help.
