Inbound caller id formatting like 0521-123-456-1
Discussion in '3CX Phone System - General' started by GI Germany, Dec 28, 2017.
  1. GI Germany
    Dec 28, 2017
    11
    do you have any ideas how i can format my inbound caller ID to make it more readable?
    i did not find anything to make segmentations blocks...
  2. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    220
  3. GI Germany
    Dec 28, 2017
    11
    i have read this several times but i can't find a solution. Probably i'm i little stupid. i only want to put a few blank spaces or strings in the number to mahe it more readable
  4. sip.bg
    Nov 7, 2016
    704
    220
    Probably you can easily reformat the incoming caller-ID for example (...)(...)(....) -- a 10-digit US number to 1-\1-\2-\3, e.g. number like 1234567890 to 1-123-456-7890. More difficult for Germany, where numbers and area codes are different lengths, you must create too many rules.
    #4 sip.bg, Dec 28, 2017
  5. GI Germany
    Dec 28, 2017
    11
    there is no possibility to create a variable rule? but if i create for every areacode as many rules as there are possibilities of lengths it should work?
    i think it is annoying to read a 12 or 13 digit number in 1 block.
  6. sip.bg
    Nov 7, 2016
    704
    220
    (.*) means one or more digits, can obviously be used as last field
    You can use rules like to make numbers more readable:
    49521(...)(.*) to 0521-\1-\2
    4989(...)(.*) to 089-\1-\2
    4930(...)(.*) to 030-\1-\2
    and so on.
    Last rule may be (order is important):
    49(...)(...)(.*) to 0\1-\2-\3
    to handle all other cases.
  7. GI Germany
    Dec 28, 2017
    11
    Amazing! Thank you so much!
  8. leejor
    11,079
    324
    Keep in mind that display limitations, on some devices, may cause the number to scroll off the screen if there are too many characters. Some devices may also add their own digit separators
