Solved Inbound caller ID: Turn off Prepend?
Discussion in '3CX Phone System - General' started by giwm, Feb 20, 2017.
  1. giwm
    giwm New Member
    Sep 27, 2016
    246
    42
    #1 giwm, Feb 20, 2017
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,783
    563
    Hello @giwm
    Navigate to Settings / company phonebook then click on phonebook options. Under the "Inbound name to Caller ID" un-select the Add queue, group and DID names to caller ID.
    Hope this helps
    giwm likes this.
  3. giwm
    giwm New Member
    Sep 27, 2016
    246
    42
    Yes, thank you!
  4. DanielM
    Mar 3, 2017
    9
    Thank's guys, solved my issue to!
  5. giwm
    giwm New Member
    Sep 27, 2016
    246
    42
    Hmm... now where is this hiding in SP5?
  6. DanielM
    Mar 3, 2017
    9
    @giwm from Dashboard, navigate to Contacts and select Options, is the last one. "Add Group, Queue or DID/DDI Names to Caller ID"
    giwm likes this.
  7. giwm
    giwm New Member
    Sep 27, 2016
    246
    42
