Inbound calls do not ring phones
Discussion in '3CX Phone System - General' started by Marcellop, Jul 28, 2007.
  1. Marcellop
    Jun 17, 2007
    9
    We can dial outbound calls withuout a problem. However, inbound calls do not ring the phones and this is the log comment:
    20:22:15.688 Endpoint::findSource [CM010001] Line configuration does not allow identification of the source of this call. Check Advanced Options for Gateways and Providers and match a field to a correct value from the following: Contact IP: '192.168.1.104'; From: 'unknown'; To: '10000'; Rline: '10000'; Contact: '10000'
  2. Marcellop
    Jun 17, 2007
    9
    Sorry, failed to mention the phones are Grandstream GXP2000, and the FXO GXW4104.
  3. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    Did you use the 4104 predefined template when adding the PSTN line?
  4. Marcellop
    Jun 17, 2007
    9
    Yes, the template was used.
  5. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Refer to your log. Your GXW4104 register to 3CX box should be failed.
  6. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    I forgot to add onto mine:
    Did you use the setup guide for the 4104 that 3CX put together?
    http: //www.3cx.com/voip-gateways/Grandstream-GXW-41044108/ NO LONGER AVAILABLE. NEW LINK: http://www.3cx.com/support/
