inbound calls fail
Discussion in '3CX Phone System - General' started by Dan wayne, Dec 16, 2016.
  1. Dan wayne
    Dec 16, 2016
    So I have green lights on the SIP trunk and I can make outbound calls no problem. Firewall is open on ports 5060 and 9000-9500 and came up greens lights on the firewall checker. What am I missing? I've run freepbx and elastix servers no problem so this isn't my first rodeo.
    Dan
    10,360
    226
    Check the 3CX Activity logs to see if there is a sign of one of the calls. If 3CX is receiving it, then the log should show what is happening to it.
  3. Dan wayne
    Dec 16, 2016
    It doesnt appear so..is there a verbosity log I can watch real time while I make test calls in 3CX?
  4. deanril@yahoo.com
    Oct 27, 2016
    51
    Vitelity is my Voip provider they have me open 10,000-20,000 as well.
  5. cobaltit
    cobaltit Active Member
    Mar 22, 2012
    733
    112
    That's because they don't know any better. Default RTP range for many Asterisk deployments is 10000-20000. 3CX is 9000-9500. But either way it's not an audio issue at this point as the SIP traffic doesn't appear to be hitting the PBX
  6. cobaltit
    Mar 22, 2012
    733
    112
    I would check that your port forwarding rules are pointing to the right internal destination. Also, you don't mention if you are registration or IP based authentication. But it sounds like calls aren't even hitting the PBX which would indicate either a firewall issue or routing/trunk config issue on the provider side.
