Inbound Calls generating 407 authentication required message
Discussion in '3CX Phone System - General' started by Ozemondaz, Dec 30, 2016.
  1. Ozemondaz
    Dec 30, 2016
    My outbound calls are working just fine but when I try to call in it kicks back a 407 Proxy Authentication Required Message. I have my SIP trunk configured with no authentication so I'm wondering if there is another setting somewhere that is making this happen.
    Thank you,
    Oze
    10,737
    278
    You might want to list the provider you are using in the chance that someone else, on the forum, has had experience with them and the settings required.
  3. Ozemondaz
    Dec 30, 2016
    My provider is Level 3 so i am using the Generic Provider with authentication set to Do not require - IP based.
  4. Ozemondaz
    Dec 30, 2016
    I have copied the log sent by my provider showing the 407 response.
    [83, 18:22:25:553990, 407 Proxy Authentication Required, 557 bytes, 10.1.254.254, 100.125.24.93, 5060, 5060] (open in a new window)
    Summary:
    Response Code: 407
    Response Reason: Proxy Authentication Required
    To: <sip:+13039743000@10.1.254.254:5060>;tag=c53ecc63
    From: "Level 3 Tech's NAME" <sip:+18147010013@100.125.24.93:5060>;tag=gK0603ee93
    Call-ID: 1866869436_81770901@100.125.24.93
    CSeq: 8762144 INVITE
    Detail Data:
    ---- ETH ----
    Destination Address : 00-10-6B-03-D5-07
    Source Address : E4-81-84-6F-CD-57
    ---- ETH II ----
    81-00 = 8100h [33024d] Type : VLAN
    ---- Vlan ----
    {000. .... .... ....} | Priority : 0
    {...0 .... .... ....} | CFI : 0
    {.... 0010 1011 1101} | Vlan ID : 701
    ---- Vlan ----
    {.... 0000 1101 0010} | Vlan ID : 210
    08-00 = 800h [2048d] Protocol Type : IP Internet IP (IPv4)
    ---- IPv4 ----
    ---- IP header ----
    {0100 ....} | version : IP Internet Protocol
    {.... 0101} | Header length : in 32 bit units - must be 5 or more
    ---- Type of Service ----
    {000. ....} | Precedence : Routine
    {...0 ....} | Delay : Normal
    {.... 0...} | Throughput : Normal
    {.... .0..} | Reliability : Normal
    {.... ..0.} | ECN Capable Transport(ECT) : No
    {.... ...0} | Congestion Experienced(CE) : No
    02-17 = 217h [535d] Total Length : in octets, including header length - must not be less than 20
    74-20 = 7420h [29728d] Identification : 29728
    {0... ....} | reserved : Not Set
    {.0.. ....} | Don't Fragment (DF bit) : Not Set
    {..0. ....} | More Fragments (MF bit) : Not Set
    Fragment offset:
    {...0 0000} | bits 12-8 : 0
    {0000 0000} | bits 7-0 : 0
    00-00 = 00h [000d] Fragment offset : 0
    {0111 1100}= 7Ch [124d] Time to live : Hops
    {0001 0001}= 11h [017d] protocol : UDP
    42-DC = 42DCh [17116d] header checksum : 17116
    source ip address : 10.1.254.254
    destination ip address : 100.125.24.93
    ---- IP datagram ----
    ---- UDP ----
    ---- UDP header ----
    13-C4 = 13C4h [5060d] source port : 5060
    13-C4 = 13C4h [5060d] destination port : 5060
    02-03 = 203h [515d] length: octets incl header not less than 8) : 515
    AB-FC = ABFCh [44028d] checksum : 44028
    ---- UDP Datagram Data ----
    ---- SIP ----
    SIP/2.0 407 Proxy Authentication Required
    Via: SIP/2.0/UDP 100.125.24.93:5060;branch=z9hG4bK06Ba95cd9acf8378984
    Proxy-Authenticate: Digest nonce="414d535c0e7639c192:36af4f05e7fd01f7dcf0d55416cba15f",algorithm=MD5,realm="3CXPhoneSystem"
    User-Agent: 3CXPhoneSystem 15.0.57336.0 (56355)
    Content-Length: 0
  5. MRM
    MRM
    Dec 21, 2016
    53
    Hi Oz,
    This code is similar to 401 - Unauthorized, but indicates that the client should first authenticate with a proxy server. The same discussion applies to error 407 as to error 401, except that an additional proxy server is involved for 407.
    Regards
  6. Ozemondaz
    Dec 30, 2016
    MRM,
    Is this error popping up due to a setting in the 3CX?
    Oze
  7. MRM
    MRM
    Dec 21, 2016
    53
