Inbound calls not answer
Discussion in '3CX Phone System - General' started by dionh, Apr 17, 2007.
  1. dionh
    Mar 3, 2007
    23
    We are unable to except inbound calls, get the following error message.
    using Grandsteam gateway if this makes any differance.
    13:40:38.890 Endpoint::findSource Can not find source by following specs: From: 'unknown'; To: '528301'; Rline: '528301'; Contact: '10001'
    Hand a look at the following post but not make any differance.
    http://www.3cx.com/forums/viewtopic.php?t=1146&highlight=rline
    Dion
  2. dionh
    Mar 3, 2007
    23
    Have got this working now, I need to add the internal number to the Grandstream gateway and not the external line numbers.
    13:54:58.343 CallConf::Rejected Call (C:2) is rejected: Destination is not answering
    13:54:58.343 StratInOut::eek:nCancel Call from Ln:10001@GW-8 to 1000 has been terminated; reason:
    13:54:43.265 CallConf::eek:nIncoming Incoming call from Ln:10001@GW-8 to sip:10001@192.168.19.62
    Howerver the CLI is displayed as unknow number how can i fix this?
    Kind regards,
    Dion
  3. NigelG
    Mar 29, 2007
    48
    Check that the grandstream is capable of passing caller ID to the system, also check the VOIP provider passes this data and that the inbound calling number is not witheld
    Regards
    NigelG
  4. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,937
    250
    Is the call actually coming in though and can you answer it? Because from the log it seems there is still an error. With CLI do you mean the caller ID of the caller on the actual SIP phone?
  5. dionh
    Mar 3, 2007
    23
    Hi Nick
    Yes, the call comes in and I can answer the call no problem; but the Caller ID is not displayed ie the incoming telephone is not displayed on the handset.
    The inbound calling number is not witheld.
    Kind regards,
    Dion
