Solved inbound calls not connecting - 404
Discussion in '3CX Phone System - General' started by Bret Gordon, Jun 16, 2017.
  1. Bret Gordon
    Jun 16, 2017
    24
    Hi, I can't figure out why inbound calls aren't connecting. I have set up a trunk with Flowroute with a DID, set it up in 3CX with the template, configured outgoing route and incoming route (to IVR ext.), and several extensions.
    Inter-office and outgoing calls work fine.
    Event log shows:
    Call or Registration to 1405XXXXXXX@(Ln.10000@Flowroute) has failed. 216.115.69.144 replied: 404 Not Found; from IP:216.115.69.144:5060
    What does this mean???
  2. Bret Gordon
    Jun 16, 2017
    24
    Why does Flowroute send a 404? As I mentioned, it is registered and outgoing calls work perfectly. Surely someone knows what this indicates. While I'm new to 3CX, I have 35+ years experience and 20 in Linux. Just trying to understand how I may have configured 3CX wrong. TIA
  3. leejor
    10,565
    245
    That log would indicate that the particular call did not go through, that the number you send was not found. If calls do seem to be working, then I would contact the provider for an explanation.
    What does a log look like for an incoming call? Is there one? If not, then perhaps it is your registration information that is incorrect.
  4. Bret Gordon
    Jun 16, 2017
    24
    Thank you. I'll contact Flowroute tech support. I've been unable to receive any incoming calls at all, so no logs other than what I posted. :(
  5. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    5,425
    352
    Hello @Bret Gordon
    Please try navigating to the trunk Inbound parameters and enable the option "Look for the DID number in these fields".
    Then configure it like the screen shot below
    Let us know if that worked.
    SomeInactive and Mike Chadwick like this.
  6. Bret Gordon
    Jun 16, 2017
    24
    That did the trick. Thank you!
  7. YiannisH_3CX
    May 10, 2016
    5,425
    352
    Glad to hear the issue is resolved :)
