inbound calls not working
Discussion in '3CX Phone System - General' started by rodneyeid, Aug 8, 2007.
  1. rodneyeid
    Aug 8, 2007
    18
    i have a problem in recieving inbound calls. i can call another extension, but when i try to call my extension nothing happens, it doesnt connect.
    any help?
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Please post your system log.
    What is the connection type of your extension (LAN or remote)?
    What is your phone (softphone or hardware)?
    Please provide brand and model as well.
  3. rodneyeid
    Aug 8, 2007
    18
    ok ,
    i have a server here in my company and remote users log on to this server.
    my c onnection type is DSL 1MB
    i am using 3cx software phone.
    my router has NAT enabled, and i disabled the firewall
  4. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Pleae try to use X-Lite for a soft phone instead of 3cx soft phone.
    The free version is available here:
    http://www.counterpath.com/index.php?menu=Products&smenu=xlite
