Inbound calls on Aastra 53i not working
Discussion in 'Windows' started by chwebb1, Nov 14, 2011.
  1. chwebb1
    Aug 16, 2010
    20
    Hello All,
    I am having some issues receiving inbound calls on a 53i running firmware 3.2.2.56, the latest available from Aastra. The phone will not work on either internal or external calls. I have tried resetting the phone to factory defaults and reprovisioning the phone, which didn't work. Does anyone have any suggestions? I have attahed the relevant part of the log below, with some information redacted. In the log below, the Aastra phone is ext. 1004, and the phone I'm using to call it is ext. 1000.
    Thanks for your help.
    Code:
    22:08:45.169|.\Call.cpp(48)|Log5||??:Currently active calls [none]<br>
    22:09:04.272|.\CallLeg.cpp(143)|Log5||CallLeg::onNewCall:[CM500002]: Info on incoming INVITE:
    INVITE sip:1004@192.168.0.4 SIP/2.0
    Via: SIP/2.0/UDP 192.168.0.29:5060;branch=z9hG4bK-4d8a-12ee5aa-1287095
    Max-Forwards: 70
    Contact: <sip:1000@192.168.0.29:5060>
    To: <sip:1004@192.168.0.4>
    From: "XXXXXXXXXXXXX"<sip:1000@192.168.0.4>;tag=95862508-c0a8001d-13c4-50029-4d8a-366ce7c1-4d8a
    Call-ID: 95845b78-c0a8001d-13c4-50029-4d8a-394eadf3-4d8a
    CSeq: 2 INVITE
    Allow: UPDATE
    Proxy-Authorization: Digest username="1000",realm="3CXPhoneSystem",nonce="414d535c04d1175075:cf5a2286b33882cda25df334e50ede8a",uri="sip:1004@192.168.0.4",response="0913ea1c753461c31becec168caaf42d",algorithm=MD5
    Supported: replaces
    User-Agent: LGN/IP8820
    Content-Length: 0
    <br>
    22:09:04.286|.\CallCtrl.cpp(346)|Log2||CallCtrl::onIncomingCall:[CM503001]: Call(18): Incoming call from Ext.1000 to <sip:1004@192.168.0.4><br>
    22:09:04.289|.\Extension.cpp(1406)|Log3||Extension::printEndpointInfo:[CM505001]: Ext.1000: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [LGN/IP8820] PBX contact: [sip:1000@192.168.0.24:5060]<br>
    22:09:04.289|.\CallLeg.cpp(1194)|Log5||CallLeg::setRemoteSdp:Remote SDP is set for legC:18.1<br>
    22:09:04.291|.\SLServer.cpp(861)|Log5|MediaServer|MediaServerReporting::SetRemoteParty:[MS210000] C:18.1:Offer received. RTP connection: 192.168.0.29:23026(23027)<br>
    22:09:04.291|.\CallCtrl.cpp(529)|Log3||CallCtrl::onSelectRouteReq:[CM503010]: Making route(s) to <sip:1004@192.168.0.4><br>
    22:09:04.291|.\CallCtrl.cpp(708)|Log2||CallCtrl::onSelectRouteReq:[CM503004]: Call(18): Route 1: Ext:Ext.1004@[Dev:sip:1004@192.168.0.34:5060;transport=udp]<br>
    22:09:04.332|.\SLServer.cpp(861)|Log5|MediaServer|MediaServerReporting::SetRemoteParty:[MS210002] C:18.2:Offer provided. Connection(transcoding mode): 192.168.0.24:7066(7067)<br>
    22:09:04.333|.\Target.cpp(441)|Log2||Target::makeOneInvite:[CM503025]: Call(18): Calling Ext:Ext.1004@[Dev:sip:1004@192.168.0.34:5060;transport=udp]<br>
    22:09:04.432|.\CallLeg.cpp(326)|Log2||CallLeg::onFailure:[CM503003]: Call(18): Call to sip:1004@192.168.0.4:5060 has failed; Cause: 503 Service Unavailable; from IP:192.168.0.34:5060<br>
    22:09:04.433|.\Call.cpp(1091)|Log2||Call::RouteFailed:[CM503016]: Call(18): Attempt to reach <sip:1004@192.168.0.4> failed. Reason: Server Failure<br>
    22:09:04.433|.\Call.cpp(605)|Log2||Call::DoEndCall:[CM503020]: Normal call termination. Reason: Server Failure<br>
