Inbound DID for 3CX Fax Extension
Discussion in '3CX Phone System - General' started by cbongard, Nov 28, 2011.
  1. cbongard
    Nov 8, 2011
    40
    I am trying to assign an inbound DID number to our fax extension, but having difficulty. I have gone to the "Inbound Rules", selected the DID I want to use, modified the "office hours" to "Send fax to" and then selected "email of extension 8998" Ext 8998 is my "3CX Fax Server extension".
    When I attempt to send a fax to the DID number, I receive the following in the Server event log (on Verbose mode), and the fax fails:
    14:50:48.954 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    INVITE sip:8594882023@66.42.232.134:5060 SIP/2.0
    Via: SIP/2.0/UDP 208.93.224.230;rport=5060;branch=z9hG4bKZZaHKmvBBHa7B
    Max-Forwards: 66
    Contact: <sip:8883160276@208.93.224.230:5060>
    To: <sip:8594882023@66.42.232.134:5060>
    From: "8883160276"<sip:8883160276@208.93.224.230>;tag=jcX4yZgKy51Qa
    Call-ID: 1c739c6b-949d-122f-66b8-f04da240ae8e
    CSeq: 20918860 INVITE
    Allow: INVITE, ACK, BYE, CANCEL, OPTIONS, MESSAGE, UPDATE, INFO, REGISTER, REFER, NOTIFY
    Supported: timer, precondition, path, replaces
    User-Agent: Broadvox Fusion
    Allow-Events: talk, hold, refer
    Privacy: none
    P-Asserted-Identity: "8883160276" <sip:8883160276@208.93.224.230>
    Content-Length: 0
    14:50:48.954 [CM302001]: Authorization system can not identify source of: SipReq: INVITE 8594882023@66.42.232.134:5060 tid=ZZaHKmvBBHa7B cseq=INVITE contact=8883160276@208.93.224.230:5060 / 20918860 from(wire)
    Any idea how to fix this?
  2. paul1
    Jan 14, 2010
    80
    Does it work if you point that same DID to a regular extension. It looks like an authorization problem with your VOIP connection. I don't think it has anything to do with the Fax.
  3. cbongard
    Nov 8, 2011
    40
    Yes, I have several other DIDs working.
  4. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    This problem is something else (not related to fax). Try pointing that DID to a regular extension to check it is working.
    Regarding faxes, please note that only T.38 fax can be received to e-mail, otherwise you must use a FXS adapter (like Cisco/Linksys SPA-2102/3102 and others) and fax machine (fax modem). Also extension must be defined as fax extension (not regular) in order to be able to receive faxes to its e-mail.
    Regards
  5. cbongard
    Nov 8, 2011
    40
    I had the same problem with my other DIDs. I fixed it by adding the full phone Nber in both the extension outgoing caller ID and the SIP ID fields on the extension "other" tab. This information is not on the fax extension configuration page.
