Inbound FAX intercepting with 1 PSTN telephone number
Discussion in '3CX Phone System - General' started by Davide Arcari, Mar 12, 2018.
  1. Davide Arcari
    Mar 8, 2018
    is there a way to intercept fax tone with 3cx (ISDN 1 Bri, 1 number so no possibility to use DID) and send it to the FAX server extension for e-mail conversion?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,381
    278
    Hello @Davide Arcari
    Do you mean you want the 3CX server to automatically detect if the incoming call is a normal call or Fax and send to the appropriate destination?
    If that is the case then no, you need to use a dedicated DID for faxing and direct it accordingly to the desired destination.
