Inbound fax pickup
Discussion in '3CX Phone System - General' started by karshah, Jan 6, 2008.
  1. karshah
    Dec 21, 2007
    5
    We have a 2nd NexVortex DID hitting our 3cx version 5 box. This number is for faxes only. 3cx sees the incoming call and directs to the 888 fax box. That's about it. It disconnects with the following error:
    [CM503003]: Call(116): Call to sip:888@pbx.corp.premieridcare.com:5060 has failed; Cause: 404 Requested user not found; from IP:192.168.7.8
    This was preceded by audio codec negotiation issues. Any advice would be very appreciated.
    Thanks and hope your New Year has started off well.
  2. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    First suggestion would be to direct that number to a regular extension, then call it. Would establish if a general setup issue or specific to the fax extension.
  3. karshah
    Dec 21, 2007
    5
    Routing to extension
    Routing to an extension works. Sound quality very good. I'm using G711.
