Inbound routes for PSTN Sangoma by DID
Discussion in '3CX Phone System - General' started by mtheory3cx, Aug 13, 2012.
  1. mtheory3cx
    Jul 26, 2012
    20
    Recently, I had to rebuild our 3CX server and now our inbound routes aren't coming in by the DID inbound rule. They used to.
    Scenario:
    3CX v10, Sangoma A101 PRI 1port, Netborder Express Gateway
    Sangoma configured as PSTN gateway, port 10000
    ~25 DIDs
    Created the PSTN gateway for Sangoma using 3CX's template. Adding the DIDs and then generated config file.
    Imported the config file in Netborder Express after configuring the gateway
    Inbound and outbound calls are flowing.
    Have been trying to configure each DID to have it's own inbound route (e.g. go to IVR, ring group, etc); however, they follow the PSTN's inbound route.
    Sent Sangoma my config files and routing table, they said it was a 3CX issue.
    I am not good with SIP knowledge for inbound and outbound parameters. If someone can help, that would be fantastic. Here are my logs for a test phone call:
    19:29:09.611 [CM503008]: Call(1544): Call is terminated
    19:29:04.327 Session 289955 of leg C:1544.1 is confirmed
    19:29:04.235 [CM503007]: Call(1544): Device joined: sip:802@127.0.0.1:40600;rinstance=671ccfe7f4076352
    19:29:04.231 [CM503007]: Call(1544): Device joined: sip:10000@192.168.11.61:5066
    19:29:04.228 [MS210003] C:1544.1:Answer provided. Connection(transcoding mode[unsecure]):192.168.11.61:7036(7037)
    19:29:04.221 [MS210001] C:1544.2:Answer received. RTP connection[unsecure]: 127.0.0.1:40710(40711)
    19:29:04.218 Remote SDP is set for legC:1544.2
    19:29:04.212 [CM505001]: Ext.802: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX IVR;Rev: 1] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX IVR] PBX contact: [sip:802@127.0.0.1:5060]
    19:29:04.211 [CM503002]: Call(1544): Alerting sip:802@127.0.0.1:40600;rinstance=671ccfe7f4076352
    19:29:04.053 [CM503025]: Call(1544): Calling Ext:Ext.802@[Dev:sip:802@127.0.0.1:40600;rinstance=671ccfe7f4076352]
    19:29:04.050 [MS210002] C:1544.2:Offer provided. Connection(transcoding mode): 127.0.0.1:7038(7039)
    19:29:04.020 [CM503004]: Call(1544): Route 1: Ext:Ext.802@[Dev:sip:802@127.0.0.1:40600;rinstance=671ccfe7f4076352]
    19:29:04.019 [CM503010]: Making route(s) to <sip:802@192.168.11.61:5060>
    19:29:04.018 [MS210000] C:1544.1:Offer received. RTP connection: 192.168.11.61:16886(16887)
    19:29:04.015 Remote SDP is set for legC:1544.1
    19:29:04.011 [CM503001]: Call(1544): Incoming call from 5555555555@(Ln.10000@Sangoma) to <sip:802@192.168.11.61:5060>
    19:29:03.992 [CM503012]: Inbound out-of-office hours rule (unnamed) for 10000 forwards to DN:802
    19:29:03.990 Looking for inbound target: called=10000; caller=5555555555
    19:29:03.987 [CM500002]: Info on incoming INVITE:
    INVITE sip:10000@192.168.11.61:5060;transport=udp SIP/2.0
    Via: SIP/2.0/UDP 192.168.11.61:5066;rport=5066;branch=z9hG4bKd225c3ee-e100-11e1-9fe8-f88d540e3c01
    Max-Forwards: 70
    Contact: <sip:10000@192.168.11.61:5066;transport=udp>
    To: "2222222222"<sip:2222222222@192.168.11.61:5060>
    From: "WIRELESS CALLER"<sip:5555555555@192.168.11.61:5066>;tag=pxip-callid-1344392943-932606-16337-3060ds-7e93-2863435c
    Call-ID: d223619e-e100-11e1-8ea5-be064cef10cc@3CX
    CSeq: 27390 INVITE
    Expires: 179
    Allow: INVITE, ACK, BYE, CANCEL, NOTIFY, INFO, OPTIONS, REFER
    Date: Wed, 08 Aug 2012 02:29:03 GMT
    Supported: replaces, 100rel
    User-Agent: Netborder Express Gateway/4.3.3
    Content-Length: 0
  2. mtheory3cx
    Jul 26, 2012
    20
    Bump? I apologize if my first post was too verbose but I wanted to give as much information as I could.
  3. mtheory3cx
    Jul 26, 2012
    20
    Bump! Has anyone even installed a Sangoma PRI with Netborder Express? If so, was there anything special you had to do to have inbound calls route through DID? Sangoma told me it is a 3CX SIP rules configuration. Even thoughts or comments would help. Thanks.
  4. mtheory3cx
    Jul 26, 2012
    20
    UPDATE: For future reference, I'll post the results of my success on this issue in case anyone else needs it. But for some reason, in the inbound parameters of the PSTN, under "call source identification", I shouldn't have had "Request Line URI: User Part" ---> AuthID: authentication
    And under Content of SIP fields, I needed to remove that last line: "Request Line URI: User Part ---> "CalledNum" number that has been dialed
    After I removed those, inbound routes by DID were working flawlessly. Hope that helps anyone.
