Inbound routing to echo service (*777)
Discussion in '3CX Phone System - General' started by jarlel, Jun 23, 2011.
  1. jarlel
    May 24, 2011
    8
    Hi!
    Is it possible to set up 3CX to route inbound calls directly to the echo service (*777) so that the call is
    answered and one can test two-way voice from e.g. a mobile phone calling to a DID?
    Thanks in advance for any help!
    BR,
    Jarle
  2. nbailey
    nbailey Member
    Jan 31, 2011
    359
    You could set an inbound route to hit a ring group with 5 sec timeout then enter in the forward to external number and enter *777 as the external number, a bit of a workaround but it works.
    Thanks,
    Nate
  3. jarlel
    May 24, 2011
    8
    Thanks for the tip!
    I just set "Forward to outside number" directly on the DID and that worked.
    Is it possible to do something similar for another DID that connects to a "music" extension where one can
    hear music played continuously?
    BR,
    Jarle
  4. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Digital receptionist.
    Prompt: music file
    Timeout: 1 sec.
    Action: End call to play file once, or Repeat prompt to make infinite loop.
