Inbound Rule DID Matching
Discussion in '3CX Phone System - General' started by tiagomoreira, Feb 5, 2016.
  1. tiagomoreira
    Dec 6, 2015
    5
    I need to map several DID's from my ISP to all my extensions, how can I do that with one rule?
    For example...I have the numbering 223 234 100 - 223 234 199, and all my extensions are from 100 to 199. How can I match the last 3 digits to route the calls to the extension.
    Someone calls 223 234 105, I receive 4105 from the ISP, and I need the call to go to 105 extension. Do I need to create 100 different inbound rules to do that match?
    Thanks...
  2. Charles_3CX
    Charles_3CX New Member
    3CX Support
    Jul 6, 2015
    114
    Hi There
    Please see this guide on how to configure DID's so that they are matched by the system so to direct the calls to specific destinations: http://www.3cx.com/docs/trunk-management/#h.nusclef3pffi
    The best way ring multiple phones from one DID is to create either Ring Groups or Call Queues: http://www.3cx.com/docs/ring-groups-paging-intercom/
    http://www.3cx.com/docs/call-queues/
  3. tiagomoreira
    Dec 6, 2015
    5
    I already looked at those links.
    But the idea is not to ring multiple destinations, is to match all incoming calls by the last 3 digits.
    From what I see I'll have to create 100 inbound rules, like:
    4100 - 100
    4101 - 101
    4102 - 102
    4199 - 199.
    Do you know what I mean?
  4. Charles_3CX
    3CX Support
    Jul 6, 2015
    114
    In this case you will have to create each one with its own inbound rule but it is not a good idea to match the last 3 digits only as this will create conflicts within the system, you should match with at least 5 so:
    *34101 - 101
    *34102 - 102
    You may need to ask your provider to increase the number of digits they send.
  5. tiagomoreira
    Dec 6, 2015
    5
    Ok...that was what I was afraid of :)
    No problem...I import all the inbound rules.
    The ISP already sends all the digits...I was just saying this as an example!
    Thank you very much!
