Inbound rule for all calls
Discussion in '3CX Phone System - General' started by yorchh, Aug 5, 2015.
  1. yorchh
    Aug 4, 2015
    Hi there!
    I have a new 3CX 12.5 version. 4 PSTN lines through Patton Gateway. I created a digital receptionist.
    Now I want all incoming calls go to this digital receptionist. I created an inbound rule.
    At "Inbound Rule type" I selected "Caller ID number/mask" option.
    My question is: how do I specify a number/mask pattern to match any call?
    I tried to specify "*" but 3CX won’t let me to do that because it says is very dangerous.
    Hope you can help me.
    Thank you!
    11,113
    329
    With PSTN trunks, all within the same group, I seem to recall that it was pretty a straight forward option (a check box) to send all calls to a specific destination, in your case, an DR. It is once you put in VoIP trunks and DIDs that inbound routing becomes a bit more complicated.
  3. yorchh
    Aug 4, 2015
    Oh, that's correct.
    At VoIP/PSTN Gateways / Patton / extension#
    At each option you can configure what to do. Now I just selected the option “Connect to Digital Receptionist”
    I deleted the inbound rule I just created.
    Thank you leejor! :D
